Display case spotlights are miniature LED accent lights designed for use in retail display cases and museum exhibit cases. These directional lights are indispensable tools for focal illumination, highlighting special features, creating visual interests, attracting attention, or fostering energy, against the background of the general illuminance. Display case spotlights heighten drama by directing concentrated beams of light on objects. The ratio of the luminance of an object to its immediate background should be at lease 3:1. More dramatic accent lighting for creating visual impacts may require contrast ratios of 5:1 or greater. Spotlights are typically classified by beam distribution as "Spot" (10 to 15 degrees), "Narrow Spots" (10 to 15 degrees), and "Very Narrow Spot" (10 to 15 degrees).
