Linear inground lights are used to for ground-recessed lighting applications where they produce controlled beams of light to create a cohesive spatial experience and underline the desired character of the environment they serve. They are designed to be installed flush with the level of the ground, driveways, pathways, or hardscape surface. The recessed installation allows the fixtures to blend in with the surroundings, without altering the visual composition of urban and architectural environments. Available with symmetrical or asymmetrical light distribution, linear recessed ground lights are versatile to accommodate a variety of architectural and landscape lighting applications. Inground uplights are used as accent lights to transform landscape elements, such as a shrub, tree or sculpture, into visually dramatic features.
