Wolf Safety Lamp Company
Company Wolf Safety Lamp Company
Wolf Safety Lamp Company - Designs and manufactures portable, temporary and installed hazardous area lighting. Sheffield, UK.
Wolf Safety is the world’s leading manufacturer of hazardous area portable, temporary, and now, installed lighting, offering the widest range of ATEX and IECEx certified explosion protected lighting and power distribution systems designed in the United Kingdom for safe use in potentially explosive atmospheres worldwide.
Our ATEX lighting range includes:
  • Portable Ex Lighting - Handheld straight and right-angled torches, headtorches, handlamps, including the renowned Wolflite...
Read more about Wolf Safety Lamp Company...
If you are a customer or client having positive or negative experiences with Wolf Safety Lamp Company, or one of those having various forms of relations with this company, get your voice heard here by the company or those who share a common interest. If you want to establish partnership with them or are interested in their products but need more information to make a decision, ask around here to harness the power of community. You may also check out the company profile of Wolf Safety Lamp Company to learn about their products and services, review and rate them, read their reviews and view their ratings.
If you are a staff member of Wolf Safety Lamp Company, jump into the conversation and create positive interactions with your audience to drive business growth. This thread is also your place to introduce your products and services. It is part of the information kit of your company or brand. You may provide supplemental information here to endorse other modules (product listings, company updates, customer reviews) of the information kit. Company updates, which keep people about what your company is up to, will show up in this thread as well.
Wolf Safety Lamp Company has a new update entry:
Wolf Safety LED Torches ATEX certified to Gas Zone 0/1 and Dust Zone 21
Our ATEX Compact Safety LED torch range is ATEX certified to Gas Zone 0/1 and Dust Zone 21. The TR/TS-60 and 65 are compact, lightweight, ATEX LED torches for safe use in the most demanding Hazardous Area workspaces. The torches are available in both right angle and straight versions.
With a maximum light output of up to 330 lumens, the Zone 0 TR-65 and TS-65 have 3 power modes, are lightweight, compact and robust. Reliable, durable and easy to use and carry, they are ideal for use in the...
Wolf Safety Lamp Company Introduces ATEX, IECEx and UKEX Zone 1,2/21,22 Certified Tower Light
NEW! The WTL ATEX Towerlite™ - a fully certified tower light solution which delivers a large, wide spread of bright light over medium to large sized Hazardous Area work spaces.
The WTL Wolf ATEX Towerlite™ is a strong, sturdy, and robust fully ATEX, IECEx and UKEX Zone 1,2/21,22 certified transportable tower light solution which can extend to up to 5.5 metres high. Fitted with three powerful and fully adjustable LED LFX2 Floodlites, the tower delivers up to 78,000 lumens of intense, bright...
SOVI™ (Safe Optimal Voltage Indicator) technology has been developed by Wolf Safety and incorporated into our ATEX certified Hazardous Area Temporary Lighting range to further enhance safety in potentially explosive atmospheres and ensure that your lighting solution is operating effectively and at the optimal voltage. SOVI™ is a feature on the Linkex™ LED Temporary Luminaire range, Linkex™ Floodlite™ range and Linkex™ Tank Lighting kits.
In the unlikely event that the light is operating at a voltage above the maximum certified limit, the beam will pulse bright to dim, clearly warning the operator to take the appropriate action to ensure that work can continue safely in the Hazardous Area.
However, it is more common for issues to occur at the lower end of the voltage range. For example, on 24-volt lights, if too many lights are strung together and the transformer is overloaded, voltage could drop below the optimal level and light output will reduce accordingly. If this does occur, SOVI™ ensures the light will pulse bright, clearly showing that the lamp is not operating at its optimal voltage level – even though the light itself is still safe, as it is certified down to 0 volts. This is different from other ATEX lights on the market, where a reduced voltage supply can lead to the light operating outside the certified voltage range.
The clear, visual warning system means that there is no need for a specific electrical resource to set up or move the lighting; its plug and play nature means that there is no safety risk in connecting too many lights together and you are clearly alerted if input voltage, and consequently light output, falls below optimum levels or exceeds the maximum safe level.
